Re: Anyone heard of an 83mm "steel headgasket or were
The original "shim" steel head gaskets were part of a "compression lowering kit", P/N 502227, intended for use in countries where high octane fuel was not available. The kit also included a thicker steel spacer and longer pushrods. Installing both gaskets plus the spacer (which ISTR was something like 1/8" tall) lowered compression considerably.
Then some smart guy (probably Kas Kastner) figured out that the "shim" steel gasket used alone (in place of the stock composition head gasket) would boost the compression ratio a bit, giving a bit more 'oomph' in racing.
I believe the factory steel gaskets (202275) were big enough to use with 86mm bores (they are listed for both 83mm and 86mm low compression kits in the TR4 SPC). However, since they are only formed sheet steel, it's trivial to cut away part of the gasket, allowing for larger bores and even relieving the bore around the intake valve (which I believe was another Kastner trick). As I recall, the gasket I got from BFE (which probably came from Moss) had to be trimmed to not protrude into my 87mm bores.
FWIW, I have an early TR3 short block where the pistons will kiss the head with a shim steel head gasket installed. If you are considering installing one, it might be wise to check the deck height. It might be just coincidence that I got two blocks in a row that weren't machined just right, but I am guessing there are more around.
