Anyone heard of an 83mm "steel headgasket or were
karls59tr
all steel headgaskets 87/88mm? Also Moss says their Corgasyl steel head gasket is for lower compression engines. I thought a steel headgasket would raise compression? Or are they two different headgaskets? One is a "Corgasyl Steel" head gasket and the other is just referred to as a Shim steel" headgasket?
Twosheds
Re: Anyone heard of an 83mm "steel headgasket or were
For use on lower compression engines or...
to lower the compression of an engine?
TR3driver
Great Pumpkin - R.I.P
The original "shim" steel head gaskets were part of a "compression lowering kit", P/N 502227, intended for use in countries where high octane fuel was not available. The kit also included a thicker steel spacer and longer pushrods. Installing both gaskets plus the spacer (which ISTR was something like 1/8" tall) lowered compression considerably.
Then some smart guy (probably Kas Kastner) figured out that the "shim" steel gasket used alone (in place of the stock composition head gasket) would boost the compression ratio a bit, giving a bit more 'oomph' in racing.
I believe the factory steel gaskets (202275) were big enough to use with 86mm bores (they are listed for both 83mm and 86mm low compression kits in the TR4 SPC). However, since they are only formed sheet steel, it's trivial to cut away part of the gasket, allowing for larger bores and even relieving the bore around the intake valve (which I believe was another Kastner trick). As I recall, the gasket I got from BFE (which probably came from Moss) had to be trimmed to not protrude into my 87mm bores.
FWIW, I have an early TR3 short block where the pistons will kiss the head with a shim steel head gasket installed. If you are considering installing one, it might be wise to check the deck height. It might be just coincidence that I got two blocks in a row that weren't machined just right, but I am guessing there are more around.
Darrell_Walker
And allow for the fact that the rods stretch a bit once the engine is spinning.
I purchased a solid copper head gasket from Gasketworks for a mild bump in CR. Mordy Dunst recommended the 0.032" as the thinnest I should go with stock rods, even though he also carries a 0.022".
-Darrell
TR3driver
Seems like I used an abrasive burr mounted in a Dremel, but I don't recall for sure. It was whatever Ken G. suggested.
Or check in the "Competition Preparation Guide", I think it had a suggestion as well.
Darrell_Walker
For my copper gasket, I used a sanding drum in a drill press (this was to clear the area around the intake valve).
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
John Turney Anyone heard of an Innocenti Sprite? Spridgets 17
S Has anyone ever seen or heard of this? Austin Healey 9
Brosky Anyone heard from Bill about engine issues? Triumph 7
timbn2 anyone ever heard of "Limora.com" ? Austin Healey 2
1 Has anyone ever heard this tip? "Weeping" head MG 11
H anyone heard of this noise? Austin Healey 2
SCguy Has anyone ever heard of Accel Oil? Triumph 0
Webb Sledge Paeco Tuning? Anyone heard of them? Triumph 3
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 8
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
T Hurst Line-Lok/Roll Control/Launch Control - anyone use? Spridgets 5
Got_All_4 TR2/3/3A Just Discovered These Alternator Conversion Anyone Do One Triumph 15
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
M Anyone Have Experience with Moto Build Ashley or Speedwell Repro Hardtops? Spridgets 2
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
pan Goodwood Revival anyone? Austin Healey 15
