V
vagt6
Anyone "encapsulated" their home?
It's all the rage among HVAC and insulation contractors nowadays: <span style="font-weight: bold">encapsulation</span>.
They spray foam (5" - 8") between the rafters in the attic and vents, literally cutting the attic off from outside air. Moisture, they say, may escape through the cells in the foam. Temperatures are supposed to stay between 50 (winter) and 80 (summer) degrees. The atmosphere in the entire attic space is "conditioned".
For the crawl space (currently no insulation, open to outside air) will also be encapsulated ( have no basement, it's about a 3-4 foot crawl space, roughly 1800 sq ft). The "floor" (dirt) and walls (block/brick) of the crawl space will be covered by a fairly thick plastic liner, with foam sprayed around the top periphery and end caps. No foam on the floor, to allow air exchange. This literally cuts the crawl space off from outside air. It will also be vented to the HVAC system with a sensor to keep ambient moisture below 50%.
This encapsulation process will allegedly reduce my heating/cooling bills by a minimum of 50%! Plus reduce wear and tear on the HVAC systems, reduce mold/moisture/pollen (better for allergies), etc., etc.
Cost for my 3200 sq foot home: <span style="font-weight: bold">about $13,000</span>.
By the way, I'm also now adding a 1200 sq. foot addition (garage with living space above), seems a good time to do this.
I figure the "payback" or ROI should be very roughly about 10-12 years (I intend to stay in this house forever, or until I croak, whichever comes first).
Has anyone else done this? Opinions?
I would not have considered this a few years ago, but now, with rising fuel costs an inescapable reality, it makes sense.
What do ye think, guys? Would you do it?
By the way, I'm also now adding a 1200 sq. foot addition (garage with living space above), seems a good time to do this.I figure the "payback" or ROI should be very roughly about 10-12 years (I intend to stay in this house forever, or until I croak, whichever comes first).
