I am in need of some assistance from any Dart owners who have an Austin Healey rear end. I have an AH rear end that came without any emergency /handbrake components. I was able to locate all of the components (swivel, rods, clevis pins, brake levers etc) and am trying to dry fit them before powder coating the components themselves and the axle housing but found that the bracket which was originally welded to the housing was ground off and tossed by the PO. I believe I can find the correct location that will work and have a new bracket made up and welded on, but it looks like it will attach directly over the chassis tube on the right side and am concerned about any clearance issues (also wondering if there are any clearance issues with the rods themselves). If there is anybody who can post or send me pictures of an AH (BJ8 or 3000) rear end insitu on an SP250 it would be greatly appreciated as my body is still off as are obviously my wheels so I can not see how the car sits on the frame/suspension (which is the original leaf springs/dampers). Thank you.
Hi Guest!
