Any Ideas
mallard
I friend gave me this part and said he thought he knew what it was. After looking I can find nothing to confirm his idea.Can anybody ID this part and what car would it go to. It looks like a great way to add 3.5 pounds to your car. It does have a number on it (V2794S)
Don Elliott
It looks like an item that is used on some TR4s to reduce resonance vibration at 3000 RPM in the exhaust pipe. It is mounted towards the rear end of the gearbox and is commonly called a "lump".
TR3driver
Great Pumpkin - R.I.P
:iagree:
Except I think it's P/N 132604 and called a "weight and bush assembly, vibration damper".
TR4nut
4A's as well I think - the side strap makes me think its from a 4A probably for the exhaust but I might be wrong.
frankenstang57
:iagree:
Exhaust related for sure.
Lou Metelko
The 4A non OD transmission (CT72579) in my garage has that damper attached at the very rear. That side strap went forward to a brace that also holds the reversing switch.
Lou Metelko
Auburn, Indiana
trrdster2000
It was wrapped on the back of the transmission and whether it worked or not is up for debate. I have even saw them on the back of a overdrive.
Wayne
PS I got one if you think you need another LOL.
HerronScott
Yep had one on the back of the non-overdrive transmission that was in my original TR4A. I'm sure I have it in a box somewhere with the rest of the parts that were left after I converted it to overdrive.
Scott
M
mallard
Well my friend was right in his thinking. One of many high tech ideas used by Triumph. I may have to get a TR4 so I can put it to use.
Maybe I could paint it real nice and use it as a Christmas tree ornament.
M
mallard
Well I've never seen one of these before and now there's one for sale on Ebay (strange).
JerryVV
It's on my 4A as well. The strap goes between the damper and the cup that contains the shift lever on the top cover. The through bolt of the cup goes thru the strap, the cup, the top cover and the shift lever.
No association with any back up light switch that I've ever seen. TR4A's never came with back up lights. 250's yes. Don't know if this damper was installed on 250's.
TR3driver
That's curious, since the SPC shows "Fitted from gearbox No CT17815 up to Gearbox No CT35719". Is it possible your car has received a transplant?
And, not to be too picky, but a backup (aka reverse) lamp was listed as an optional accessory for TR2 through TR4A. I don't know how many were actually fitted, but it seems likely there were at least a few. However I agree that there was no strap to the switch, since it was installed like an OD switch through the top cover (except over the reverse rail).
Geo Hahn
TR3driver said:
That's curious, since the SPC shows "Fitted from gearbox No CT17815 up to Gearbox No CT35719"...
Mine is in that range and indeed had one. When I replaced the original gearbox with an OD I retained that mini-boat anchor. What wuz I thinking? Things are crowded enough (and heavy enough) back there w/o having that thing. Next gearbox R&R I may end up with a new paperweight.
TR4nut
I think they went past that number and definitely into the 4A's. I've seen too many 4A's with them. Perhaps they were not mounted universally, however? Possibly some ad hoc testing and the dampener added as needed?
sail
My originally non OD 4A has a strap from the shifter to the gearbox mount and exhaust bracket but no damper.
JerryVV
Well what was I thinking. That strap does go to the exhaust bracket not the top cover (my bad)There is another strap that goes from the Trans mount to the top cover. Randall, I wonder where the one TR3 thru TR4A with Backup lights fitted originally from the Factory is now, seriously I wonder how many were actually fitted. I know some others have done what I've done and drilled and tapped the top cover and installed a back up light isolator switch. My friends laugh at me but I don't care, it's my car.
There is a photo of the rear of my car on this site that shows the BU Light below the left side rear.
TR3driver
I guess you could ask Bill Piggott; he found one to take a picture of.
Deleted member 8987
Several other marques used weights that bolted to a drilled ridge under the tailshaft housing, and some either/and a weight bolted onto the nose of the diff.
However, one would think that part shown could be used to balance out a badly bent driveshaft in an emergency.
Joke, son, just a joke!
JerryVV
I tried to communicate with Mr Piggott once and was told he didn't use e-mail so I wrote a message to his publisher with a clarification for his book. He lists colors and interior choices for TR4A's as fitted from the Factory. My combination is not listed so I thought he'd be interested in a clarification. The responses that I got were basically that he knew better than anyone what was and what was not supplied, Thank You very much and we won't try to get your message to him as he's a very busy and very important person who doesn't want to be disturbed. My opinion of him is different at this point. His books are all very nice but they are just that. I'd consider John McCarthy to be a much better source for information. All Mr Piggott would have needed to do is some research at the Heritage Foundation and he could have verified my information. I guess is's too important for that.
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
