TexasKnucklehead
Thank-you Keith and David for the previous threads regarding battery box replacement -I can't say how many times I read them. Apparently the battery box is welded to the 2 little backing plates and to the boxes on either side (bulk head assy) before the top of the scuttle is welded. Getting a cutting wheel under the scuttle to cut those edges loose is difficult.
I drilled all the spot welds including the two in front of the box, carefully cut away the corner welds (and upper lip), and was then able to extract the original and force a new box in. It goes home with a pop! I haven't welded it in yet, but it looks like progress.
There are three "T"s for wiring on my original box. 1 on the right side, 1 on the back and 1 on the bottom. I wouldn't put the one on the right side until after the box is in place. It is a tight fit already.
I noticed, on the new battery box, the angle brackets were welded with 2 spot welds, while the original has 3 smaller welds. Does it need welded better?
The scuttle area in the center near the vent, was slightly raised before taking the box out -you can see the greater separation there in my picture. Some of of it is probably due to prying, but not all of it. Is that normal? I'm thinking, if I weld in the proper sequence, that raised area my be straightened out because of the straight edge on the new box. I have been looking forward to battery box replacement with great consternation ever since I knew it had to be done. So far so good...
