T
Tinster
I really hate always being the stupid kid on
the block, I really do.
I still don't quite have this timing procedure down pat.
My car either dies at stop signs or idles at 1500 rpms.
The 3 rear plugs are black no matter what it seems I
attempt. I think I have a timing issue.
My dizzy has two "ears".
There are two small pipes on my carbs that run to the
ears on the dizzy.
The pipe on the front carb originates on top.
The pipe on the rear carb originates on the bottom.
1. Which pipe do I pull off to set my timing?
top pipe or bottom pipe?
2. I set my timing gun to 12, is this correct?
3. My timing wheel has two marks. Big one, small one.
After I disconnect the correct timing pipe--
Do I rotate the dizzy until the big line hits the marker
with the gun set at 12?
Or set the gun a zero, turn the dizzy to get the line and
marker together and then turn the timing gun knob to 12
and line up the small mark?
Sorry to be so dense on this one. I really can't fool with
the carbs until I am certain I have timed the beast
correctly.
PS: Crypty being Crypty! The car actually started today
and I moved it to the street to clean up the mess that
under it. beautiful blue sky above. Turned my back, Crypty
brought in a black cloud and filled himself with rainwater
while i was recycling a cup of coffee in the john.
tin
ears on the dizzy.
correctly.
tin
