CJD
I've taken 3 off without a problem. They appeared untouched original boxes, though. I bet PO's have a tendency to over tighten the shaft nut. With 60 year old parts I always stay to the low end of the torque range, especially when the nut has a tab lock. It won't be coming off!
Bobby, if we're talking a full rebuild...you'll want to replace:
The upper worm shaft seal/packing.
The pitman seal at the bottom.
The pitman bushng (mentioned by others)
New peg (cheap, but often you can re-use the original by turning it)
Top cover gasket.
Remarkably, the front cover uses shims, not a gasket. I seal them with locktite 518 on both sides of the shims. It seals, does not harden, squeezes out so as not to add to the shim stack thickness, and any globs on the inside will resolve and not cause a problem.
Edit...and likely a new olive...
Top cover gasket.
