Another, oh! just the same old electrical short!
Jim Weatherford
Well, with a British car that is watched over by Lord Lucas like my '73 Jensen Healey Mk.I you can only be sure that you will have electrical problems, again and again.
I have a short in my horn circuit, it's not at the horn down stream but... seemingly in the horn lever, somewhere I've "fixed it" 3 X and the same problem seems to re-appear. The circuit will be fine then the lower fuse in the fuse block will blow and no horn! My turn signals work but the horn lever and switch is having problems.
Not having a horn as low and light as we are is dangerous when the monster trucks and SUV’s driven by fools with their stereo’s up to 110 dbs and a cell phone stuck… in their ear, pulling over on you with very few options… and no horn.
I wondering out loud if it wouldn’t be better to install a horn button in place of the cig.lighter and be done with it. Any ideas?
90 XJ-S
Jim,
Your problem is most likely in the cabling in/on the steering column. Good Luck. I would persevere and fix it... No WAY would i be putting one of those horn button thingies on My JH. /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonod.gif /ubbthreads/images/graemlins/nonono.gif
Also, just some food for thought... Do you really think any of those jerks you just described can hear your 75 - 95 db LBC horn? /ubbthreads/images/graemlins/confused.gif
Please, defensive driving must be the religion of we LBC owners. Watch out for the other jerk. /ubbthreads/images/graemlins/thumbsup.gif
Your horn won't help, unless you want to get the attention of that fine, young ... /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/driving.gif
Mike
Steve
Platinum
You could always install some of those Italian Fiamm air horns.....mama mia!! Wonderful noise. You may need to re-wire the horn, but I would be reluctant to install a button in the lighter socket.
J
Jim Weatherford
When I firse purchased my JH the first thing I did was get the 118db Hella horns and replace the peeper that was on it. I had Hellas on my cobra replica and it woke a few folks from their stuper. Seriously I have no problem loosing the lighter scoket, I don't smoke and besides it's rotted out, I was going to machine a plug for it anyway.
V
vagt6
Jim, I had the same problem on my GT6. The PO installed a couple of VERY loud horns using the old wiring. I blew fuses and lived without a horn for months, then finally rewired them. I agree, there's nothing worse than a horn failure in today's five o'clock traffic, especially when you're in a GT6 looking up at everyone's SUV hubcaps!
New horn wiring = No more horn problems.
J
Jim Weatherford
Mark;
Glad to know it's not just me. LOL The JH is even lower, I'm often looking up to guys in Miatas and BMW Z3 & 4's.
I previously owned a Cobra replica and I loved it, hated to give it up. The JH is the closest thing in feel and is as rare as origonal Cobra's. As an aside, I parked next to a Cobra at a show recently and I was stunned at how much smaller the JH is that a 427 Cobra replica.
V
vagt6
Jim, you indicate your JH is powered by Lotus. I'm not very familiar with these. Is it a Lotus 4 cylinder engine? Would you be able to post us a pic of your car?
J
Jim Weatherford
Mark;
I have a few shots in the gallery. The JH's were powered by the Lotus 907 engine, twin overhead cam naturally and belt driven (basically 1/2 of a V-8 45 degree angle). They are typical of developmental Lotus engines, almost every one had slight improvements over the life of the manufacturing cycle (3 years), slightly different from engine to engine. It is the grandparent of todays Lotus engines.
I just had the roll bar raised 3" and added a forward FIA style bar adding considerable strength and when I called SCCA I found out it is approved for Solo II which is a plus.
Over the weekend I discovered that the valve guides are shot, my Black Beauty is followed by clouds of black smoke, darn, it is always something.
Write me if you would like more info. I'm gonna try and post the new photos today. Thanks.
Bugeye58
Jim, clouds of black smoke would seem to indicate a mixture that is too rich, rather than valve guides. Guides create clouds of bluish white smoke.
Check your plugs and see if they aren't black and fluffy.
Then make sure your chokes are opening all the way.
Jeff
V
vagt6
Very nice car, and thanks for the explanation. I've always admired the Lotus, mostly since the Europa was introduced way back when (1970 ish?).
Good luck with the smoking problem, maybe you'll get lucky and it won't be so hard to repair.
Cheers!
Super 7
907's were sold in the US until 1980 at least in the Elite/Eclat.
The turbo version was sold here until about '97 in Esprit. Lots more than 3 years. But it was continuously improved over that period.
My 7 is kind of low and small too. I can place my palm flat on the pavement without leaning over in the driver's seat. Driving it you face Miata's squarely in the license plate. The hood is lower than the top of the low profile 13" tires. The top of the windshield is 39" off the ground. The weight is about half that of an MGB, early Miata, or early JH at just under 1100lbs with all fluids.
I actually drag it to the side in the garage by hand to make more room in there to park the other stuff.
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
AngliaGT ANOTHER TR6,& an MGB Spotted 0
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
