Healey Nut
Does the soft top drain channel on a BJ8 rivet to the rear shroud behind the rear shroud lip or to the front of the lip that then gets covered with the chrome rail ?
The drain channel can be twisted into correct place with about three guys. Mine was accidentally left off my car when it was restored but they were able to get it into place. About a 50/50 chance to get it in without having to loosen the shroud. Pop rivets work fine.Healey nut
I am just finishing repairing my drain channel and what I found out on a previous post (check that as some good pictures on there) is that the lip of the drain channel should be behind the lip of the shroud, which is a problem for me as my shroud is allready in place !
Would you use ali or stainless rivets to prevent rusting ?
Also my drain has one centrall outlet but others i have seen have one either side behind the rear seats, which is correct for a BJ7?
Thanks
Rob
BJ8's have three drain outlets. I don't know about BJ7's.Patrick
Should the drain channel have 3 outlets on it as bit concerned mine only has one in the middle !!
A Note about the Drain channels. There are the two drains that are near the doors, so technically I have 5 drains with hoses connected to them.BJ8's have three drain outlets. I don't know about BJ7's.
Here's a pic of the channel when it was out of my car.A Note about the Drain channels. There are the two drains that are near the doors, so technically I have 5 drains with hoses connected to them.
