TR2/3/3A Another Carb question.
Having swapped out the jet for one I had in my spare box I had no leak so I put the original jet back and no leak. I moved the jet up and down and suddenly it leaked again then noticed the jet bearing moved a bit. Tightened the large nut a further flat and no leak. I thought I had it tight before.
I will check the tightness again in the morning.
David
Oh the fuel line looks fun David, I even see some electrical in there. Are you selling it on EBay. Anyways I have had the same problem with the large cork gasket. I think Joe wanted them soaked in oil, but I cannot remember. There is hardly any fuel pressure maybe 2 to 4 lbs so they are kinda gravity leaks. Sounds to me like you have it; they just take time to get correct.
The electrical was from the non working electric pump. The power feed to the pump had beer run between the floor and frame.
David
