Bob_Blue_BJ8
Everyone:
I really appreciate all of the replies and value your advice and counsel.
The guy who is working on the car now is terrific (If you're in the MD/DC area send me a PM and I'll give you a referral - hope this doesn't violate any forum rules). He has put in a lot of time mulling over how to address my problem.
Anyway, I still want to explore the camber adjusting plates that can be mounted atop the shock towers. If they do it for racing, then I figure they have to hold up pretty well for street use. Does anyone have experience with them? Will they deal with a wheel that already has a lot of negative camber? Rather than use them (which requires cutting off the existing mounting plate), can you cut the outboard end of the existing mount plate to insert a sliding plate with bolts in it and elongate the holes in the existing plate to allow moving the shock?
