Bruce_B
In the middle of the (edge)top flange, there's a hole
used for mounting. It's located just in front of where the
mirror is mounted.
If I feel under the dash, just behind the mirror (towards the passenger seats) there's a fixed bolt. Does that bolt
go into the hole on the dash for fix the dash in position?
So far for mounting I've located 1 hole on each upper side of the dash where a screw fits. These are located behind the windscreen posts. You have to open the doors to drop the screws in. There's also two rods extending from the car that screw into the bottom of the dash.
Is that it, the 5 mounting positions?
What have I learned...more pictures next time!
mirror is mounted.
