another adjustable steering column question
IanIrving
I've been trying to get my steering wheel to straight ahead rather than five degrees off. It's the adjustable type column and I've pulled the traficator head out till it's just out of the lower stator tube. Now I can't get it back in. I know it only fits in one way because of the dimples on the short tube but I can't seem to find a way to get it back together. Anyone suggest why?
Thanks
Ian
I
IanIrving
Thanks John
It went back after several more tries. It seems with most things Healey, obstinance is the best policy.
Ian
Keoke
:savewave:
Hey Bill!!!:
Put the referenced site in your favorites list it is a winner.--Fwiw--Keoke
Legal Bill
Ian, I looked through, but I'm not sure I see where it says how to get the wheel lined up straight. My traficator is fine. I'm just off tothe left about five degrees. Too little to remove the steering wheel off the the adapter.
John Turney
#1. Make sure the steering wheel is in the straight forward position. Mine was about 90 deg off, so I parked the car in the garage with it in that position.
#2. Shut the car off, turn the battery isolation switch off.
#3. Assuming you have the adjustable wheel, loosen the three setscrews to allow you to pull the tafficator out so you can access the circlip that holds the wheel on the splines. This is at the bottom of the article about "<span style="font-weight: bold">Roger Moment’s tips for installing a new steering wheel or repairing the trafficator without removing the wiring</span>."
#4. Making sure the wheel is still in the straight-ahead position, loosen the adjustment collar and pull the wheel off the splines. Rotate the wheel to where it belongs and push back onto the splines. Replace the circlip.
#5. Reinstall the trafficator. This is where it may take several tries and some patience to get it to slide into the groove in the fixed stator tube. When it's back in, tighten the three setscrews to hold it in place.
#6. Adjust the wheel in/out until it's where you want it and tighten the adjustment collar.
#7. Drive.
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
AngliaGT ANOTHER TR6,& an MGB Spotted 0
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
D Another use for a leaf blower. Restoration & Tools 1
