Amazon engine rebuild pics
classicmechanic
For those interested, I do a lot of classic car restorations as mobile mechanic. I started putting up an Instagram and Facebook page for my work. I'll post the links in my signature.
Two days ago I removed a 67 Amazon engine, the client wants it restoring and running much better. Removal is only two/three hours tops, and the rest of the day tearing the engine apart.
The head was removed and sent to a machine shop for a skim and valve reseating. The pistons, rods, crank remained in place as I was satisfied with their condition. So, with a thorough cleanup of the block and a paint job I think the client will be happy with the result considering the tight budget (which adds a little pressure, what stays, what goes lol).
So far, the head was worked on, new camshaft and end sprocket, 1ed3 ignition fitted, injectors cleaned, new water pump, new belts, all gaskets and seals (including crank seal) have been replaced. I need to have the exhaust manifold repairs as it is badly cracked, but all that remains is finished up the rebuild.
After spending a few days on a Mercedes Pagoda, it is nice to work on a basic engine again! Love these Amazons.
Pics
Gliderman8
No new oil pump?
Gliderman8
I’m sure there’s lots more little things that you have done as well.
I had a look at your website and see you also work on scooters. I still ride my 1963 TV175 as well as my 1959 Li125.
classicmechanic
classicmechanic
Well the story goes from the client is that the engine was replaced in the 1980s with an early 70s motor. The customer has limited budget, so you have to think what can be salvaged, what is good to remain and the all important consumables such as pumps, hoses, thermostats etc etc are top of the list.
Been using the 123 ignition setups for the last two years, can't really fault them and a lot more folks are asking for them to be fitted to their old timers.
Gliderman8
Glad to see that these cars are being maintained and kept on the road.
tri_carb_healey austin healey dvd on sale at amazon!! Austin Healey 3
wkilleffer Volvo Amazon/120 Other Cars 7
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
