Alternator is Fixed!
CaptRoy
I'm back on the road..I had a friend help me today and we moved the wiring around while the engine was running and all of a sudden the light went out and the voltage went to 14.3. I found the nut on the alternator terminal was not tight where it went in the case.. It took a real thin wrench to get it. Tightened it and everything was fine.
Also I had dash lights that would only work in a certain location of the switch. I took the panel light rheostat switch out. I took it apart and cleaned the contacts with a small dremel wire wheel. Did not clean the wire coil. Lubed it and reinstalled it and it works like a dream.
While I was working I also got my front overriders installed and glove box put back in..
A great day in the garage, now the rain can go away so I can drive it!
Brosky
Congratulations for a job well done!
Happy to hear that you're ready to roll.
AltaKnight
Wow, great day!
Don't worry though, the laws of average will ensure you also get days where everything you touch.....
T TR6 Alternator wiring Triumph 4
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
J MGC Lucas alternator/regulator MG 3
