Hi everyone, As I posted some time back, I was having issues with door gaps when the car was raised and lowered. We had the usual rust behind the doors - rocker, quarter panels and small hole through the outter sill. I purchased some replacement shut panels and things are not lining up as before. After some minimal test holding with rivets and clamps, it seems the to new panel is a little further out and setting at slightly different angle to get the rear fender to line up. This make issues with the door latch pin. The old panels are at 70 degrees and these slop a little further back. We have only worked on the right side for now. Are there different panels available for 100's #223599 and earlier or after? Not finding much choice on vendors. thanks, again folks
Hi Guest!
