HealeyPassion
Finally got around to doing the final mocking up of my engine/cool air delivery. I've had this in the works for a long long time, but this is the first time I was at a point to verify all the positioning/clearances/routing. I have a bit more to do before I call it final. You may note that the fender has a channel to accommodate the duct. The air filter is inside the black tube in the middle of the run. It's been spec'd to handle up to 250 HP which is clearly more than I will need.
Hi Guest!
