jvandyke
That's a good idea actually! I had a made a piece for it from the cap on an aerosol can. It had the correct OD! Covered it in vinyl and it was ready to go..then the slip ring issue tanked it. Investment was minimal thankfully (nil).
My concern now is getting the surround/slip ring mounted correctly on the dash such that it is centered around the column. Mocked it up and marked with washable marker. Need to drill and hope, can always tweak it a bit by enlarging the screw holes through the dash. It lines up like this though....because the surround has weird angling to it.
Looked at an original steering wheel on ebay a minute ago, it looks like the hub is much deeper and the horn push sits out further so thus the longer brush...I'll make something work. I hope.
