TR6 Advice on TR6 potential purchase and title
Bruce100
I just ran into a 72 TR6 that might fit my budget. I have owned Spitfires and recently a TR3, but never a TR6. I saw it through the windows of a garage, and am going back later this week for a closer look. What TR6 specific things should I look for in evaluating it for purchase?
Also, the guy has a title that the PO signed in the presence of a notary, but left the new owner section blank. The previous owner passed away. Suggestions on how to make sure I don't get into trouble on the title?
poolboy
If you say TR6 specific, then there are 2 things that come to my mind that might set a TR6 apart from a lot of other old cars.
Rust that has weakened the outriggers that the Trailing Arms attach to.. It's fixable but dangerous if not and related in a way, is the condition of the rear wheel hubs, check for the rear wheel looseness due to worn out ungreaseable bearings.
Maybe a third, although crankshaft Thrust Washers are not unique to the TR6 engine, worth checking the crankshaft end float to see if the TW's need immediate attention.
Everything else should be fairly common to buying most any old British sportscar thats probably seen better days, yet looking for a new start in life.
An innocent preemptive phone call to your DMV could get you an answer about title transfer.
RagTopMan
He's referring to the section of the frame that part #121 (in the Moss diagram you linked to) bolts to. This is a rust prone area.
B
Bruce100
I don't have a dial indicator, and was wondering what is an inexpensive way to measure end float. Saw several sites showing use of a snap gauge and a vernier caliper. Where can I get a snap gauge locally? Suggestions?
TR3driver
Great Pumpkin - R.I.P
bgbassplyr
Dial indicators are fairly cheap. Check Harbor Freight.
mallard
If you have third party Title Co in your area I would call them. Trying to make a phone call to the DMV in AZ is not an easy thing to do.
Make sure the panel gaps in the doors are the same at top and bottom. A weak frame will cause the car to sag in the middle.
BobbyD
If possible get the car on a lift where you can really examine and "hammer" on the frame especially the TA attachment point that PB mentioned and the Tee-Shirt area which can hide a lot of rust. After that look for any sign of exterior body rust because if you can see a small bubble, chances are there's a lot you can't see. door panel gaps.........well mine have been the same for 15 years: very even along the front edge and very uneven along the back edge..........and I've got a very solid frame. In my case it's probably more a sign of body mounts needing to be replaced.
In my mind the best thing you can do is pay a shop (that both parties agree on) $100 or whatever to go through the car and give you an estimate on what needs to be done to get it through state inspection and what else needs to be done. I did that and saved $3K on the asking price.
Or look at it this way...........rust, any rust has the potential to equal BIG $$$ or even render the car unsafe to drive while anything mechanical (within reason) can be fixed for a whole lot less money.
All the Notary does is verify that the signature signer is who he is. If the name matches the title on front, there should no problem with the title. You don't have to tell the DMV anything.
TR6oldtimer
If the title change was not registered, then that implies the tags are not current which would be a minor problem.
I would not worry about the thrust bearings. While there are a few horror stories about them, they usually were on really abused and service neglected engines with high mileage. The important thing is that the engine starts. You may also want to take off the valve cover. If it is all gunked up, then the engine was not properly maintained. That does not necessarily mean there is a thrust washer issue, but maybe the gunk could be a negotiation point.
On the gaps at the rear of the door, they are normally wider at the top then at the bottom to allow for frame flex. Anything over 3/8" is of some concern.
Bubbled paint on the rocker panels or along the rear fender seams, means rust holes underneath, usually more then you would think. Lift the carpet ahead of the seats to see if the floors are still intact.
B
Bruce100
I was able to look a little closer today. Only had 5 minutes on my way between meetings! I did not have a lift, but was able to reach under where the trailing arm attaches, and could see somewhat. Could not feel or see any rust. It may or may not have been my imagination, but pushing on it with my thumb, I thought I could detect a slight deflection.
Here are pictures of the door gap on drivers side. I am concerned about the driver side door.
This gap seems too great to me... thoughts?
Re: Advice on TR6 potential purchase - Pictures
Not unusual gaps. None are quite the same. Seen more with gaps like that than not. Not much quality control on panel fits.
poolboy
:eeek: Marvin must not have looked at the picture on the previous page..
mrv8q
RE: pic #1. That would concern me, too... Yikes!
The door was closed, right?
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
S TR6 new TR6 owner looking for advice Triumph 9
B TR6 Advice on Wheels for a 72 TR6 Triumph 2
B TR6 TR6 Tire Advice Triumph 6
ScottTR6 TR6 Advice for new TR6 Soft Top Triumph 9
I TR6 TR6 hard top advice please Triumph 3
B TR6 My totaled TR6 insurance saga pt 3, advice welcome Triumph 27
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
I TR6 TR6 cylinder head rebuilding advice Triumph 15
C TR6 TR6 Advice please: weak spark? Triumph 7
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
B TR6 TR6 bumper removal - advice? Triumph 5
V TR6 TR6 Clutch Advice Triumph 14
R TR6 TR6 Steering wheel advice needed Triumph 6
jjbunn TR6 Hoping for advice on 1972 TR6 Triumph 44
I TR6 Tripod head light advice for TR6 Triumph 9
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Brosky TR6 Clutch advice needed for TR6 Triumph 19
F TR6 Advice on TR6 gearbox and rear axle fluids.., Triumph 7
Brosky TR6 Looking for tire advice for TR6 Triumph 17
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
