Wow, you guys have a lot of good knowledge and if you are willing to answer my basic questions, I will continue to ask. The enjoyment of fixing these cars almost equals the enjoyment of driving them. I am returning to spending more time working on mine and having a blast.
So I decide to go the helicoil route and decide to drill out the hole to 29/64 per helicoil instructions (there seems to be plenty of hub on the edge to accommodate this). When I get into the brake I find a lot of grease so it looks like the rear oil seal is bad. I pulled the hub and axel out. Now I presume I pull out the bearing from the hub to clean and repack it with grease and a new seal. My basic question before I start pulling things apart is if are there are any hard knock lessons waiting for me.
As a side note the knurled press in stud approach woke me up at night in a cold sweat as I envisioned what would happen if that thing strips if someone over tightens it. Wouldn’t that be a nightmare as it spins with no way to remove your wheel?
Paul
Paul
