I'm having to replace the left front shock mounting plate. Before cutting out the old, rusted plate and the awful patch on top, I did take careful measurements. The problem is that where the measurements fall on the new plate just don't look right. Off just a bit. I'm afraid to make everything permanent at this point, becuase the location of the shock determines the camber of the front spindle. A potential solution is to fit adjustable camber shock mounting plates to both sides. This is certainly possible, but expensive. Does anyone have a similar experience? And just where can I get those adjustable mounts?
