PatGalvin
Hi Guys
In a flash of brilliance, I drilled out the pin (item 21) in order to remove the bush (item 20) from the accelerator shaft. This was pretty rusty and I didn't realize that the pin needed to be driven out. So, many years later now, as I'm starting to reassemble, I need some advice how to make this repair. I think this pin (item 21) was a tapered pin that was driven into the bush. I can purchase another pin and install, but it will likely be too loose. I recall that when I drilled it out, I slightly enlarged the hole in the bush and the hole in the shaft. So, any advice on how to repair this? Thoughts much appreciated.
pat
pat
