You have the "large" accumulator. All that you see down there is the piston and rings -- there is no sleeve. The piston rides in a bore in the OD case.
IF the bore is all scarred up, you can get the "small" accumulator. That will consist of a sleeve that will fit down into the existing bore with a smaller diameter piston, a single, smaller diameter spring and a sleeve that will contain the spring. This is what Randall mentioned earlier.
The piston can be removed with compressed air applied to the actuator valve hole -- and a big towel over where the piston is going to be flying out.
It's pretty gunky looking, but I'm inclined to agree with Randall that, so far, it looks like a good core. The magnet is a donut shaped thing that lies in the bottom of the big brass cap you removed to expose the filter screen. I haven't seen a picture of that yet, but judging from the rest of what I'm looking at, I'll bet that cap contains a goodly layer of sludge in it and, perhaps, buried in that, will be the magnetic ring.
