dougie
In a promise to myself to drive my '65 BJ8 more this year, I decided to inspect the brakes and R & R the fluid. Starting with drivers right rear, I began to loosen the bleed screw and it literally feel to the garage floor. Not just the screw, but the entire cast aluminum portion of the brake wheel cylinder it threads into. After catching all the fluid that started to pouring all over the floor, I removed the brake cylinder and inspect it closer. From the attached picture you can see corrosion in the crack which indicates it was there for a while and may have let go at anytime......Yikes!
There's my question. Moss sells 2 types of replacements, an original Girling at $116.95 or an "aftermarket" version for $32.95. Any suggestions or experience with these? Or even an other vender you'd suggest.
Many Thanks,
Many Thanks,
