texas_bugeye
I wonder about the fuel filter you have BEFORE the pump.
It could be that the filter is tite enough to put a restriction that the facet cant pull enough fuel at your high demand running rate. I also have tha facet pump but I use a simple strainer before the pump and a can fuel filter after the pump this setup seems to work just fine.
