A few engine questions.
JOeyKnapp
I had to replace the bypass water fitting on my head because the original one was rusted and wouldn't come out. I took the head off this afternoon (will post the fitting pictures later).
When I got it off and started cleaning a little I noticed a few things and wondered if someone had any answers about them.
The first is a "U" stamped on the head, near the thermostat. Did that ever happen to designate unleaded? Or is that normal?
The second is on the underside of the head 080 is stamped. Bore change?
The third is that 3 pistons were P17 and one was P19. Don't know if that means anything? Just curious..
Gerard
I don't believe those are stock markings, rather probably done by the shop that rebuilt it. The U could indeed be for "unleaded". The number 080 on the head is probably how much has been removed (which is a LOT).
J
JOeyKnapp
So, you are saying it's a high compression race motor!!?? :smile:
Thanks for the insight. Looking at the minimal amount of buildup on the valves I was thinking it had been apart before.
Is there a "best practice" for doing anything before the head goes back on with an engine you don't know anything about? For instance, should I take it to a machine shop to have them check to see if it is warped or anything? (I have only had experience with aluminum heads, due to my Honda and Type1 VW experience..)
Whitephrog
I have a 948cc engine which was modified by Howard's Machine Shop in Huntsville Alabama in the early 1970s. At the time they were building NASCAR engines. I don't yet know what all they did to the engine. The only obvious modification is that the pistons are 30 over.
I have the same but smaller "U" stamped on the head. On the block near the front I have stamped a small "P" and a bit larger "JF".
Gerard
The pistons do look like they have a very small dish as well.
It would probably be a good idea to check for any warpage. I would also check the valves for any leaks. A shop can do it at the same time, but you can do your own little self test by inverting the head and pouring enough solvent (i.e. lacquer thinner) to form a little pool around the valves and see if any leaks/drips develop.
Another indication of how fresh the rebuild might be is to look at the cylinder walls. Can you see or feel a ridge at the top of the bore (where the piston rings don't reach)? Can you see any cross hatch pattern still remaining in the bore? These would both be indications of low milage.
Spridget64SC
The 'U' on the head is a rather common stamping. I've got A-Series heads of all types and there is usually a letter code on the head.
What is your head casting number? And, is this a 948 or 1098 engine? Usually found between the 2nd and 3rd rocker stand location. If it is a 12G206 or 12G295 head, then 0.080" off the head is a typical cut to get the compression back to where a 948 engine started. Remember that the 1098 heads have a few more cc's in them that the original 948 heads.
From what I see with the exhaust valves being pocketed as much as they are, the head has not been converted to un-leaded fuel use, that is, hardened valve seats. The valves would stand a lot more proud and there would have been a seat insert circle/seam visable.
The 3 with the cap means that the bore finished out at BMC to fit size code 3 pistons. In the very early days, size codes went from 1 to 4. A bit more displacement with the 3's. There should be a 3 in a diamond near one of the tall head studs opposite each cylinder. Also, all cylinders may not have the same size pistons. I've seen different sizes in a single cylinder before. The 2013 is the part number of the piston. Front is front meaning the pin is offset for noise reduction with the amount of stroke in the engine. These are shallow dish, high compression (9.0ish, IIRC) pistons.
As long as you weren't having any sealing issues with the valves or head gasket, I would put it back on and torque to spec's.
HTH,
Mike Miller
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
G Spitfire Starting Spit engine after sitting a few years Triumph 3
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
AngliaGT A Few More Local Vehicles Spotted 5
AngliaGT A Few More I saw Yesterday Spotted 10
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT A Few More along Highway 220 Spotted 3
AngliaGT A Few Interesting Vehicles Spotted 32
AngliaGT Went & Looked at a Few Cortinas Tuesday Spotted 17
trrdster2000 Spitfire Added a few pictures to my Photo Album of the Spit6. Triumph 0
Rob Glasgow A few Years in Between Austin Healey 20
AngliaGT A Few Interesting Cars Yesterday Spotted 0
V Last few months in the UK Pictures TVR 5
AngliaGT Saw a Few Along the Trip Spotted 4
V Spa Classic 2017 a few TVRs present TVR 1
DrEntropy Off Topic Been a busy few months... MG 7
C TR6 72 TR6 Project. A few new pics Triumph 5
Steve Spotted in the Milwaukee area in the past few weeks... British Motor Corp 0
AngliaGT ........ A Few More Questions Spridgets 7
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
drooartz A few Morris pics Spridgets 7
drooartz A few new parts for my new-parts shelves! Spridgets 4
Steve Thought I'd Share A Few Photos.... Other British Cars 5
W Likely need a few Bugeye inner body panel parts Spridgets 0
aeronca65t A few minutes of in-car video from Watkins Glen -Oct 10,2014 Racing 5
coldplugs Darned few... Spotted 2
D TR6 First few days with First triumph Triumph 15
drooartz Need a few cheap/free projects Spridgets 14
J A few Q's for the SP250 owners Other British Cars 2
blueosprey90 A few VSCCA laps at Pocono, July 2012 Racing 7
TR6oldtimer TR4/4A A few TR4 things free Triumph 1
Frankenhealey Bahamas Speed Week Revival - a few places left Austin Healey 8
M_and_P Wanted: A few Bits Spridgets 3
dougie A Few Laps in a 100-S Austin Healey 2
H TR2/3/3A A few TR3 questions Triumph 8
F Final touches- a few detail questions for a BJ7 Austin Healey 11
Johnny Here's a few alternative colors for AH.. Austin Healey 0
aeronca65t Woodwork-a few photos TVR 1
Sherlock A few old cars [including one Brit] Spotted 0
AngliaGT A Few Different Ones... Spotted 0
B TR6 Need a few opinions on parting out/pricing for TR6 Triumph 8
jackq MGB-GT FOUND>>>on the way in a few minutes MG 14
aeronca65t a few pictures-last weekend Racing 1
jackq Huge yard with a few thousand cars Other Cars 12
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
angelfj1 Project Up-date and a Few Questions Triumph 20
Brosky Two down, one to go.., actually a few to go Triumph 4
S A few triumph questions.... Triumph 12
