Michael J.
I can't get the idle below 1100 rpm, 1400 when cold. I have looked at all the vacuum lines, sealed any that were loose, retorqued the intake manifolds, checked the butterfly settings. I changed the carbon canister.
Is the pcv valve to be open at idle?
The idle adjustment is screwed in all the way.
This car has a manual transmission kit installed and the vacuum port for the auto trans modulator is capped.
What else is there?
Any suggestions?
What else is there?
Any suggestions?
Hi Guest!
