Michael J.
John;
As suggested, I installed the pressure guage in the trunk at the inlet to the fuel filter. PSI was not better. The original pump was a Lucas 4FP P/N 73351A. The replacement I was able to obtain for that P/N is a Pierburg pump P/N 7.21287.53.0. Pressure at the inlet to the fuel filter after 18 inches of hose from the pump is 38 PSI with the car off, but ignition on and 38 with the car idling at 1200 rpm and it does increase up to 42 PSI at about 2500 RPM but the engine is very rough, but with smooth idle at 1200. The AAV is still screwed in all the way.
The ECU is a 16CU P/N DAC 6337, with a Y in a circle followed by 84787B. The date code is 4788. Is this a fuel pressure regulator issue? It appears that the pump can produce higher pressure if it receives a signal from the ECU to do so as was indicated at the higher pressure at 2500. With the RPM increased to 3000 RPM, the roughness continued , but the pressure never rose above 42 PSI. The car was not moving during this.
If you think something else will be learned, I will install the pressure guage where you think we can find out something about the pressure and drive the car to record pressures, but it does not run too smoothly.
