'76 Midget driving along then chugging?
Tipsy
Hello all, This morning in my '76 midget I was taking my son to his daily bus for summer camp, a short trip in town, and when we left the house everything was running fine. About 5 blocks away something changed and the engine started chugging. Not bucking or dieing. just a loss of power and not running well as it usually does. Last night I took a short trip to the video store and it was just fine. Several weeks ago I changed the spark plugs for fresh ones as I do in the spring since this is a fair weather car, I also topped off the oil in the carb, I have the single Stromberg.Anyone have any thoughts on which direction to troubleshoot? Carb? plugs? I have pertronix ignition. Thanks for any advice. Jeff
JPSmit
Jeff, fuel filter? what colour are your plugs?
T
Tipsy
JP, I will check this evening and report back. Thanks for the fuel filter idea, I never thought of that.
Blackjokr
I'd defintiely say check the fuel filter, but is your air filter clogged?
Billm
It could easily be that one of your plug wires fell off or that one of them went bad.
BillM
T
Tipsy
One of my plug wires was popped up/loose in the distributor cap and the contact was sort of a burnt corroded color as opposed to #2, 3 and 4 which were still clean and shiny at the cap end. Guess maybe it had been loose and arcing, then finally no contact at all. Going to clean it and test it to see if that's the problem and if so get a new set of wires! Thanks everybody!
G
If you buy the universal Accel V8 soild core set you'll have enough to make two sets. IIRC I paid $18 for mine 6 years ago.
T
Tipsy
Good idea on the double set. My brand new plugs are very fouled and carboned up. I'm going to get new plugs and one of my wires was broken too. Anyone else have trouble with the #1 plug because it's right behind the alternator with no room to spare? Every time I put in new plugs the alternator, belt and bracket have to be disconnected just to get the plug out.
T
Tipsy
I'm concerned about my brand new plugs being fouled up so fast! I just put them in a few weeks ago. Only driven it a few short trips around town and already fouled up. I know my carbs a bit rich but it's never fouled this fast before.
I'm not very familiar with the stromberg, but it sounds like the choke may be sticking.
G
No, I don't have trouble, I put good plugs and wires on it. :wink: I think I have the lastest iridescent plutoniums in it. That being said, I'm with Trev. Fix it then put the good stuff in.
Jim_Gruber
"iridescent plutoniums" that along with your warp drive added to your out of round crank.
T
Tipsy
Yep, that's what I decided to try this last time. I talked with the guy at parts store. Told him what car, and that I run a bit rich. He said try the irridescant plutoniums and they should last longer...not foul so quickly. Well just the opposite happened and they fouled up quicker...I'm guessing cuz the ignition spark is such a tiny little node that as soon as it got some carbon on it then it was covered up and done for. I'm going back to my AC's.
T
Tipsy
Also, just opened up the air cleaner and found a piece of fuel hose in the carb. Must have been from when I changed fuel pump last year and changed the filter and fuel line at the carb. I think it fell into the air filter box and finally loosened itself up until it worked its way to the throat of the carb. We'll see. I've gotta move the alternator so I can replace that #1 plug again and then we'll see. Maybe it's time to tune the carb a bit...lean it out slightly so it doesn't run so rich and carbon up everything.
bthompson
Do you have the water choke on your Strommy or the manual choke? The water choke may need to be rebuilt (or replaced with a manual one -- hint hint.)
Also, check your manifold gaskets and throttle shaft for leaks. Any air leak with a Stromberg carb will drive it richer -- even if the carb itself is in good shape. (An aftermarket air filter acts as an air leak, and counterintuitively, will run rich as well.)
It's a good conversion for 1500 Midgets to replace the Accursed Stromberg with an SU from an MGB -- JP's done it, he'll have the specs. If I hadn't already swapped for a Weber I'd do it too. It's almost a bolt-in conversion; it uses the stock intake manifold. One mounting hole needs to be elongated slightly.
G
If the thing would give me 30MPG I'd do it too. I do kinda dig my side draft.
JPSmit
Easy Peasy - get an HS4 rear MGB carb, a round file, elongate the holes slightly and bolts right on - about 20 minutes work.
T
Tipsy
Manual choke on my Stromberg. Standard air filter too. Just rebuilt the carb last year, should be OK there. I think I just have the needle set too rich. It needs to be dialed down leaner a bit. I like it rich so it starts right up with no choke cuz my choke cable is not working so well but I guess I need to fix that issue. The conversion is an interesting idea though. What's better about the SU or HS4 carbs?
BugeyeNJ58 Whose driving to the Midget 50th Party? MG 1
Thor MGB How does driving a mgb compare to midget 1500 MG 10
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
