looking for proper way to check gearbox oil. dip stick is not between firewall and consoul. there is the rubber grommet, but there is no dip stick to be found any help.
thanks that was a fast response. i was searching the web and found several items. i guess i need to replace the gasket between the motor and trany, that may help stop/cut down the leak. 20-50 weight it seems to be the way...thanks
