Yes and No. I'll try to find the thread explaining and post it for your review.
Got it! Here's quoting Geo Hahn quoting Odd H:
"Here is an old post from elsewhere that I saved. Same answer as Bill's but with some explanation (and I agree about using Lucas fuses as they are also the right physical size).
==== quoting Odd H ====
A Lucas fuse is rated by what current it would blow at. Ordinary automotive fuses are rated by what current you can draw WITHOUT blowing them, or the maximum continuous current. They don't really specify at what current they'll blow...
Anyway, these old Lucas fuses of mine have both the Lucas "will blow at" rating, and the maximum continuous current rating, i.e. the normal rating labeled on them. [Or rather in them, because it is a small paper strip inside that carries this info. The more modern Lucas fuses have the info printed on the glass tube in an abbreviated form.]
So here's your equivalents:
Lucas 50 amp - continuous 25 amp
Lucas 35 amp - continuous 17 amp
Lucas 25 amp - continuous 12 amp
Lucas 20 amp - continuous 10 amp
Lucas 15 amp - continuous 8 amp
Lucas 10 amp - continuous 5 amp
Lucas 2 amp - continuous 1 amp
See the trend here? Each fuse is actually good for a continuous current that's roughly 50% of it's Lucas rating.
==== end quote ==== "
Here's the thread:
https://www.britishcarforum.com/ubbthread...true#Post121293
