TR6 71 TR6 Fuel Tank firewall?
BJones
Hi all,
I have a 71 TR6 that I bought restored. I am trying to figure out if there is supposed to be a firewall of some sort that separates the fuel tank from the cabin. My current setup has the interior panel as the only thing keeping the fuel tank from the cabin. I believe it is vinyl attached to cardboard. What came from the factory? Is this safe. My friend thinks there should be something more here for safety to keep fuel from entering the cabin if in an accident. Any help would be appreciated.
Thanks,
Twosheds
I made a firewall for my TR3 racecar that went between the fuel cell in the boot and the driver compartment. I traced around the millboard onto stainless steel aircraft firewall material. Then I cut it out with aviation snips and filed the cut smooth. It was pretty thin, about .027 if I recall correctly. So I cut my fingers a few times and said some bad words. I bent a strip to a 90° angle and bolted it to the boot floor to attach the bottom to.
I got the firewall material from Charlie Vogelsong at Dillsburg Aeroplane Works.
Don't see why you couldn't make something similar for a TR6.
TR6oldtimer
A few owners cut a piece of sheet metal and welded or riveted it to the rear cockpit, then placed the mill board and vinyl cover over it. I see no need for it, but what ever works for you is fine.
G
If you are thinking of what happened to the Pinto in years past, I have never heard of a TR6 having the same problem. They all came that way from the factory. I personally wouldn't think about it.
TR6oldtimer
Just came to mind, if you do decide to install a metal sheet between the cockpit and trunk, do it AFTER you have adjusted all body gaps. Otherwise, you stand the chance of making the tub more ridged, which will make gap adjustments more difficult, if not impossible.
As Bill said, I would pass on doing it.
B
BJones
Thanks for the input guys. Bill you are spot on with your Pinto comment. That is what he was referring to. I will probably just leave it for now.
G TR6 TR6 fuel tank fitting size. Triumph 14
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
