'70 FHC window frame and glass removal
Goodfellow
Been stumped on how to remove the passenger door window frame on a '70 FHC. All assembly drawings, pictures and R&R procedures shown in the manuals are from older versions.
How do you separate the lifting arm from the track in order to get the window assembly out?
Thank you --
Not exactly sure on a 70, but normally you raise the window a bit for clearence, and unbolt the regulator from the door. Then slide the regulator back, forward, up, down, and usually curse a bit, and roll the rollers out of the ends of the tracks. You will see that there is *just* enough room to do that On really tight quarters, sometimes you have to tilt the glass to facilitate getting the rollers out.
