TR6 69 TR6 air cleaner color
Got_All_4
Looking for the proper finish for the air cleaner box for a 1969 TR6. I'm quite sure they are black but gloss or satin black? This is not going to be a concourse restoration car but period correct.
DNK
I would do as little shine as possible with out going flat.
Also have it p'coated
martx-5
I bought a new '69 TR6 and I don't remember the air cleaner being black. I remember a hammered silver color and the two short snorkels out of the front.
Got_All_4
Got_All_4
mine is / was rust and black. Just sandblasted and primed it. I know I've seen the gray hammered look before but not up on a 69 TR6. did not see any gary underneth it ether. mine could have been switch out.
DNK
Hmmm...if that be the case, which I never doubt Ken, if your is originally black.
Must be an early 69
poolboy
There's a picture in the Piggott book of a 250 with the black box. That's how I came up with that, Don.
Maybe for some 69's it was a leftover or just a swap.
DNK
The left over is what I figured as you know, Triumph was good for that.
Swap is always a possible too.
DNK
I would think it would be the Silver that is used for a lot of the car.
But this is a WAG
What is the 69's body #
martx-5
But fot the most part they were the hammered gray look?
When I mentioned "hammered silver" in my initial post, the "hammered" part is what i recall, but may not have been so. But, it was definitely a silver color similar to the wheels...after you took off those awful Rostyle hub caps they stuffed on the '69.
Got_All_4
Got_All_4
I'm going to the TRF Summer Party next week and got an e-mail from Charles tonight that some is going to be there with a new 1969 TR6. He had new in quotation marks so what does that mean.
Must be an early 69
CC29843​
TR4nut
First TR6 I had was a 69, unfortunately I don't have the commission number - but it was a silver air cleaner, I wouldn't call it hammered I think I used the same silver as I had used on my Spitfire wheel rims - argent silver?
Got_All_4
Got_All_4
You can buy that hammered gray look in a spray can. I'll find out next week. Got to be some one at TRf that knows.
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
G TR6 TR6 air filter element replacements for stock housing Triumph 3
D TR6 76 TR6 Stromberg Air Valve Triumph 2
hondo402000 TR6 New Tires and Air pressures TR6 Triumph 9
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
hondo402000 TR6 Air suspension for Tr6 Triumph 1
floyd TR6 75 tr6 air injection system Triumph 8
T TR6 Where can I get a front air dam for a TR6? Triumph 10
JoeC TR6 TR6 Dashboard Fresh Air Vent[s] Triumph 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
