Hi All,
I have always stood in ah at the ingenuity so many have extended to the implementation of our fuel pumping system. As many of you know, I still have a points SU pump in my BJ8 Phase 1 but back in the mid 1980s, was convinced by a friend to replaced the Square bodied SU with the newer round-bodied unit used by the phase 2. Looking back, there was no necessity to do this as the pump, as with its replacement, could have been easily modified to last well past today. The modifications I have executed through the years were quite simple and included:
1) Conversion to neg. ground (no physical change needed for the SU pumps I had/have)
2) Extended point life indefinitely by addition of a Transient-Voltage Suppression diode (TVS @ $1.50). This diode is placed across the points to limit voltage passing across the points to a max of 21 Volts. Without this diode, the effects of the pump's coil could raise voltage passing across the points to multi-hundreds of volts and could cause premature points failure. with the TVS, voltage is limited to 21 volts (high enough to clean points but low enough to be below burn potential) with all access voltage gated to ground.
3) Fuel pump Inertia Switch to shut off fuel flow in case of an accident (cuts power after heavy blow or car turnover).
Due to these additions, my points pump has worked well and with little consideration for the past years and is expected to continue into the future. However, keep in mind that I have focused on the electrical longevity of the pump and their are still other components (i.e. diaphragm etc.) that still warrant aging concerns. Yes, 2 pumps can be better if one fails but also brings added complexity. New solid state pump replacements can also reduce concerns but that has not proved to be a securing move in the past for when they fail, unlike points, there really dead.
Well, just my thoughts,
Ray(64BJ8P1)
