TR2/3/3A 62 TR4 Brake caliper?
Geo Hahn
Maybe.
Depends on which 3B (TCF v TSF) and the commission number of the TR4.
The Moss catalog has good details about the 3 calipers (A, B & C) with change points:
https://mossmotors.com/triumph-tr2-3-4/brakes/brake-components/front-brakes-2
charleyf
I believe that the "C" is the same as the 62 TR4. By again checking the part numbers of both items you can verify if the same part numbers. The "C" is what is found on the TCF 3B.
K
karls59tr
Bronze
I broke a hold down bolt on the brake caliper and a friend says he has a 62 TR4 caliper but is out of town so can't check if it's the "B" type. My Vin # starts with TS not TSF. Wonder if it's the same as 59/60 TR3?
charleyf
First if your commission number begins with TS and not TSF or TCF you are not looking at a TR3B but likely a TR3 A. As to the bolt you refer to you can search the on line catalogs for Moss or TRF and check the part numbers for that bolt in the TR3 and the TR4 and see if they match.
TR3driver
Great Pumpkin - R.I.P
Bolts are the same; but IIRC the B and C calipers are not directly interchangeable. The caliper change came at the same time as the switch to 10.75 rotors; the caliper mounting plate was definitely different and I think the mounting centers changed slightly as well.
doughairfield TR4/4A TR4 Brake Caliper Re-Assembly Triumph 9
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
J TR4/4A TR4 brake problem Triumph 7
doughairfield TR4/4A Brake question on the TR4 Triumph 9
J TR4/4A TR4 Master Brake Cylinder Rebuild Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
J TR4/4A TR4 Brake question. Triumph 4
T TR6 Anyone have a spare TR4/TR6 brake master lid? Triumph 4
S TR4/4A TR4 brake problem Triumph 15
M TR4/4A TR4 Brake Drums Triumph 4
SCguy TR4/4A Brake Servo Kit for a TR4 Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
A TR4/4A TR4 hand brake boot Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
