Temp was dropping in the house. Opened the basement door and heard the condensation pump running continuously. When the condensation pump runs it shuts down the air handler so the pump doesn’t overflow.
Problem solved. The plastic tubing that exits the basement was frozen so the pump could not empty. I also have a dehumidifier in the basement that drains into the pump. Disconnected the pump and drained it then shut down the dehumidifier. Once that was done the air handler turned on and we now have heat.
