Hi Guest!
bought this to quiet the valve clatter but it had only minimal impact on the noise. Jim[/QUOTE said:You must add a sound screen barrier to the engine hood-
Whar type of hose clamps did you use on your radiator hoses?Smooth aluminum, no fins or script is what came on my '57 100-6MM. I think any improvement over the stock cover is an upgrade.
Bling aside,yes it is there but rigidity is the upgrade you get gong this way.
Regarding the bling I never liked the covers with the oil filler cap in the middle.
Bling a...
I do not understand why tappet noise was not reduced using any one of the rigid valve covers discussed.-??
A terrific deal for the small fuel injection hose clamps:
Not really the high quality stainless steel syle I've used.....
After seeing the flat non-breather caps I’m no longer sure mine is correct. I got it used about 40 years ago. I’d like to know who has the flat caps for the oil filler opening.Patrick, I would really like to see a picture of a correct filler cap - the one I have is what came with it when I bought it used. My cap is not a vent/breather but seals with a cork gasket.
Michael, That's interesting because mine has a distinct crown from front to rear which I really like. Isn't that the point of bling, something you like.
To the original questions, I don't think it's really an 'improvement" but I do like them.
Dave
Received the clamp assortment today. Quality is same as JEGS clamps above. Both are same metal thickness.
Dougie - maybe you could post source info on the SS clamps.
