TR6 3-Prong TR6 oil pressure switch
Brosky
Does anyone remember the after market part number for the TR6 later oil pressure switch? I thought that I had it on the wiring diagram, but I don't. Actually, I think that it fits a Chevy Monza from the 80's as well.
And I don't want to go through the usual Q&A at the parts stores.
Hi, I need an oil pressure switch.
OK, you have the old one?
Yup, right here.
That looks weird.
People say that from time to time.
Year - 1974 - (eyebrows curl)
Make and Model - Triumph (eyes going blank, I'm losing him)
Wait, hold on, we don't sell motorcycle parts here
No, it's a car...really..
Sorry, can't help you. Try XYZ down the street who's even more clueless than me. Later, dude.
philman
I was just looking at one on BPNW ( one of our supporting vendors) a couple of hours ago. I think they used the same one on Spitties and TR7/8's for the anti-run on valve control.
Brosky
Brosky
Phil,
I wanted to pick one up locally, rather than wait a week until it gets here from Oregon.
R
RonMacPherson
Paul, see if the "Monster List" is still up and posted. I had it linked to the hard drive on my dead computer and haven't gotten around to resurrecting the data off it.
Sounds like you're in the ball park, I vaguely remember Chevy also, Maybe someone like Buckeyes has the listing on it, or perhaps VTR.ORG.
Sorry I can't help you any more, right now.
Opa
Paul
Napa Echlin part number OP6610 is supposed to be a direct replacement also 76-79 Chevy Monza and 250 cu in Chevy six cylinder supposed to work.
No personal experience with any of the above tho.
check 'em out.
TR6oldtimer
NAPA Parts carries three....
And their on-line parts order page includes Triumph.
MPE OP6074SB $4.49
ECH OP6074 $7.29
ATM 1431009 $7.59
mrv8q
Paul, GUZZUL wrote this on March 14:
Also, to answer another post about the TRF part number for a 3-prong switch, there are some variations, so you need to check your commission number. The one for my Spit is GPS113.
This switch is plug-compatible with a standard GM switch, as used on 1979 GM models with a 5L engine. Olds Starfire, for example. Standard's number is PS-64. NAPA number is OP6610 (Echlin unit). $10.50 versus TRF's $24.95 and readily available at pretty well all engine parts places.
If you do a Napa search for "oil pressure switch" you will also bring up the links to their OP Switch sockets. Again, these are generally available from parts stores, in the range of $6-10. Makes it easier to get 'em off.
Brosky
Brosky
Thanks guys. The last one that I bought was the PS-64 and it worked well. I may try to get a socket to wire in there now that there is room to work.
Oddly, no matter what I did with the NAPA online, I couldn't get a Triumph OP switch. Just belts and other stuff.
Thanks again!
mrv8q
So, I have the NAPA OP6610 O.P.S., but have yet to install it... The 3 prongs are stamped I P S, in this configuration:
___
On the '74 TR6, there are 3 wires; a plastic plug, a black, and a purple. Can anyone confirm which goes where? TIA!
Brosky
Brosky
Ray,
These are single prong according to my local NAPA, which I don't have much faith in. I'm going to stop in CT tomorrow and check it out there.
guzzul
mrv8q said:
The 3 prongs are stamped I P S.....On the '74 TR6, there are 3 wires; a plastic plug, a black, and a purple. Can anyone confirm which goes where? TIA!
The three wires connected to the OP switch should be a) black - goes on the "P" terminal, b) a white with brown tracer - goes on the "S" terminal, and c) a white with purple tracer - which goes on the "I" terminal.
The black is ground, the white/brown feeds your oil pressure light, and the white/purple goes to one side of the A/R valve.
mrv8q
Thanks, to Ross and Paul!
Brosky TR6 Local source for TR6 3-prong oil switch ? Triumph 24
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
