Got_All_4
I'm planning on replacing the rear shackle spring bushings and possibly the fronts too. I plan on driving he car for another 20+ years then plan on giving it to the kids to enjoy. Never noticed a problem with the rear suspension but the rear fenders and doors are off so now is the time to do it. How many of the body mounts should I remove or loosen to get the rear end up high enough to pull the spring off the front mount? Also should I have the doors installed when I lift it?
Although that lean in the body is suppose to be there it's always bothered me. If the springs are off I don't plan on replacing the spacer that causes it. My question is with removing the spacer will it change my door gaps that I worked so hard to get perfect?
