MGB 1980 MGB Running fast.
ecurie_ecosse
Not sure what is going on here.Idle is okay,car drives okay until I take it out of gear sitting at the lights or stop sign.Then without using the accelerator,the engine revs start to climb.When I put it back in gearand drive off,everything seems okay.Give me a clue or two on what I'm missing. :rolleyes:
Stuart. :cheers:
I sure hope you get a good answer to this...mine does the same thing !!! Can't figure it out.
Stuart. :cheers:
How is your accelerator return spring? is it returning all the way?
Sounds like a vacuum leak. Possible carb shaft wear or even HIF shaft seals shot if you have HIF carbs. Without physically checking, it's all a guess. PJ
