Hey Folks,
I just realized I hadn't updated on this project in a bit.
Still not passing emissions, but it's not a big deal as Mum's out of town for the next month or so.
So far we've done the following:
1) Replaced all the rubber in the front suspension, including ball joints, tie rod ends, trunnions, etc. Also replaced the shock absorbers.
2) Replaced the ignition system with one of those nice setups from Jeff at Advance Distributor. New plugs as well.
3) New catalytic converter.
4) Replaced all oil-type fluids in the car. Put on the oil filter adaptor.
5) Fixed the speedometer.
Next steps:
1) Rebuild the master cylinder (it's starting to fade out at lights)
2) Rebuild the carburetor (aka put the right one on the car)
It drives SO much better than when we got it. As soon as the carb is fixed it'll pass emissions (it's running rich, and the carb that's on the car is worn, can't adjust it any more).
One question, what's the consensus on the shims on the front lower A arms? I just can't seem to get the suspension dialed in. From my reading there was some "controversy" (for lack of a better word) between the US teams and the English teams on their use to correct the suspension camber.
