I remove the broken antenna and tried to push the new antenna lead thru the hole inside the fender but there seem to be a metal plate covering the hole and preventing the antenna lead from going thru the hole. I removed the side panel inside the car where you would expect the antenna lead to enter the car and there is no sign of a hole!!!
Do I need to remove the instrument consol?
Hi Guest!
