davester
You might want to ditch the "hooked and taped together" black leads and buy yourself a single ground cable that you attach to a nut and bolt securely attached to the body...but yes, get yourself a single battery. Either buy a plain old cheapo group 26 battery or do as I did and buy a Westco AGM battery which should last a good bit longer if you don't abuse it.
Hi Guest!
