Frank Canale
I have decided to change my plan of attack. My metal forming skills still need some work so I am starting on the chassis.
The back half is off.
The front clip is ready to take flight.
Time to take the motor out. The motor is out. Time to clean up.
The good news is the motor started no problem after sitting for a little over a year, the frame disassembly went really well.
The bad news is I have discovered more frame damage than originally thought. There are two cracks on the back side of the spring tower at the bottom. It appears that someone has done some welding around this area but not to the cracks. I do not see any bulging of the frame rails. The diagonal brace that goes to the frame rail is not bent but does have a lot of rust damage to be repaired where it attaches to the frame. I am going to take my time and start the frame measurement process that is in the service manual. This week will be cold and will slow the work in the shop. If it was easy every body would be driving one. Frank
Hi Guest!
