TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play.
Tinkerman
I have about 3 to 4 inches of play in my steering. This is a brand new front end and has never been on the road. Before I start hanging front end sheet metal I would like my steering correct. Any thoughts on a starting point? In the rebuild I used all new or NOS parts. Everything was rebuilt according to the tech manuals. Any thoughts or ideas would be greatly appreciated. Cheers, Tinkerman
mrv8q
On mine, it was perished silentblocs.....
TR3driver
Great Pumpkin - R.I.P
Can you feel the tight spot with the center link disconnected from the Pitman arm? It should be very slight, but noticeable. If not, I suggest that your box isn't adjusted properly. Getting all the end play out of the box is critical as well, I wound up using a dial indicator to check it as the feeler gauge method didn't seem to come out right. The book doesn't really mention it, but I feel it is important to back off the top adjustment (or just remove the top) while setting the end float. Then afterwards, of course, set it back so you can just feel the tight spot.
Note that it is normal (design feature) to have some small play when the steering is off-center. While driving, the camber in the front suspension will take up the play.
Otherwise it's just a matter of examining every point and finding where the play creeps in. I went through a similar exercise a few months back, and discovered that the new peg had worked loose in the rocker arm. I must not have got it mounted properly or something. I also had a hard time getting the steering wheel locked tightly to the shaft; had to add a flat washer under the nut and I suspect it is working its way loose again.
FWIW, I got mad at the original silentblocs long ago, as they never seemed to last more than a few years (probably due to poor quality replacement parts). Replaced them with brass bushings and SS pins from BFE. The Delrin ones from TRF (and ARE) are probably just as good but I haven't worn out the brass ones yet. (I also added grease zerks so I could lube them from time to time.)
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Pool Dad 1960 TR3 engine serial number Triumph 14
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
G 1960 3000 BN7 Top Help Austin Healey 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
J 1960 Bugeye Paint Codes Austin Healey 1
K MGA 1960 MGA Vin MG 3
F 1960 FriskySport Barn Find Other British Cars 6
5 Proud of my 1960 Bugeye Spridgets 5
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
P 1960 Lancia Appia coupe Other Cars 1
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Nugget 1960 Bugeye "Patents" inherited reconstitution Spridgets 12
6 For Sale 1960 Bugeye Survivor for Sale with Original Rubber Mats Spridgets Classified 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
D Great Gas Mileage in Southern California [Circa 1960!] Austin Healey 3
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
red57 1960 BT7 top mounting brackets Austin Healey 4
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
T needed 1960 bugeye parts Spridgets 4
Tinkerman TR2/3/3A 1960 3A post 60,000 top installation Triumph 6
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR 3A Rear Wing Attachment Triumph 13
