Fred_the_frog
Hi, I am totally new to this forum and sofar I have spent a lot of time reading and learning.
But I currently have a big issue with my Frogeye regarding the fuel supply.
The car runs fine until it get´s warm and then kind of starves and will just stop after cooling down it will be fine again.
I have changed the mechanical pump against a Facet cube and tried the elecrical pump in the engine bay and then moved it to the back.
But, I still have the same issue!
The Facet pump will work fine until the car is warm then suddenly you hear the ticking noise as if the pump is not moving any fuel.
As I said I have read lots of threads on similar issues but everything I have tried in the past few weeks has not helped.
Additional information: Engine is the original 948 version, Twin HS2 Carbs installed, Heat Shield is installed, all fuel lines are new and checked
The Fuel bowls feel very warm but if these are vapor locking then the pump in the back of the car should still be full of fuel and would not make the clicking noise.
I really don´t know what to do anymore....
Perhaps somebody has had a similar issue or has some advice.
Grettings from Germany
"Fred_the_frog"
"Fred_the_frog"
