maxwedge5281
readying for cooler weather and thought that i would overhaul the side curtains. first thing that struck me was that the forward wind slides and not the rear panel which is fixed. i remember it being the other way on my early healeys. at any rate, is the felt liner material glued into the tracks or is it just "jammed" into place. of course the rear sliding pane will hold lots of the felt in place. but what about the track area for the window that slides. also one of the corner reinforcement steel pieces ...one of the 90 degree ones...has two of the very small screw threads stripped. are these available from any of our vendors. i could buy a used set of frames and remove the piece but that is expense that i wish to avoid. i suppose i would weld up the small holes and rethread... any other suggestions when rebuilding other than buy the later one piece frame side screens...which are much nicer but really expensive. thanks for any help!!
Hi Guest!
