Some things I learned about working with freshly rechromed parts:
1) Every thread will have to be chased to clean the chrome residue out of them so nuts will go on.
2) If you replace a part of an assembly on an MG TD, replace everything. On mine, I had to replace the radiator shell which we sent off for rechrome; but we didn't replace the grille slats and painted the original slats to match the interior. Since these are hand built cars, nothing's in the same place on 2 cars - so today we had to remove all the studs from inside the radiator shell so the grille slats would fit...that meant each stud had to be epoxied in a new place...luckily, I had some extra studs since Moss doesn't carry a part number for them (however, tomorrow I'll give you the trick for making studs when I make photos of the inside of the radiator shell - you'll need it because you can't remove the slats without breaking at least 1 stud!).)
3) When you reassemble an MG TD windshield frame that's been rechromed & are using new screws - reassemble the frame without the glass, cut the screws to length & then install the glass....no, I didn't break my glass - but, it'll be a day or so before we've got the frame assembled/disassembled & reassembled! Oh, don't install the interior front panel (kick panel) until after the windshield is in place unless you're a contortionist!
We did, however, move her out in the sun for the first time to wash down the frame/engine compartment/suspension...when we finished them & before we started on the body, my bodyman sprayed a chemical coating on everything to keep overspray off - it always looked like a film of dust...today we washed it off...it ran off like liquid dishwashing soap. The middle photo shows the coating on the frame horms - it looks like dust:
The Sequoia Creme color really changes its hue in the sun...& we've not buffed it yet!
Tomorrow, I'll take photos of the radiator shell with the grille slats installed, install it & then start on the front fenders. If anything goes as palnned, tomorrow should show some progress....I know today I worked 8 hours & can't see any!
